oil leak part 2
chandler
Well I replaced the pan gasket and that cut down the leaking but didnt stop it. Now it appears as if the oil is coming from between the bellhousing and the little metal plate infront of it. Is that even possible? Or is it just running out of my valve cover gasket and down?
when I replaced mine I the samething happened. I think the oil got behind the plate when I removed the pan, drove the car for awhile and it stopped.
Well I know my valve cover is leaking a little bit and so is my head gasket Im thinkin its the main seals...just gets better every day
