Hi My oil light is coming when braking, XW with 221 motor should I be concerned ?
I have also atattched some pics of my LPG adaptor to convert a Impco 300A to a weber throttle body onto a log head. First an adaptor was made to fit a weber carb which I ran for a while. The studs were removed for the lpg conversion. 2 weber throttle bodies were used and the top one was gutted and filled all holes with devcon and was then then matched to the custom LPG adaptor. The black silicon is to seal over the top of 4 couterunk 8mm bolts that holt it all together. The bolt heads are directly under the sealing surface of the convertor. It works great. Hope this helps anyone wanting to do it this way.
Cheers Dan
Cheers Dan
