Oil return line
rommaster2
I am going to have to drop the pan on my car to clean out the aftermath of a sheered distributor gear and so while it was down i figured i would install the return line pickup in the oil pan.
My question is where did you guys all install it, I know it needs to be above the fluid line, but it can't collide with the crank obviously.
I just welded a 5/8" JIC fitting into the side of the pan (flush on inside) and capped it. I made sure to space it BETWEEN the oilpan bolts to make sure I could access them later on. I simpley had mocked up my turbo on the motor and held up a line with it in the car and put it where it would fit...
