Eric Rose
I got my adapter from Summit yesterday. I must have gotten the wrong adapter because the 1 barrel flange was too small to bolt directly to the log or to drill and slot the corners. It would bolt to the stock carb adapter, however.
So what I did was fabricate a plate from 5/16 aluminum with the same bolt holes as the carb adapter. Then the Trans-Dapt adapter would fit on in the correct orientation and still give me more clearance than bolting it to the stock carb adapter.
The whole deal (5/16 plate/trans-dapt adapter, and carb) is onlt about 1" taller than my Carter YF. A drop-base air cleaner should make it all fit right.
Speaking of my carb, I got a Motorcraft carb from an '81 Escort with an automatic, I think it is the Carter Weber. I had to cut and paste together a throttle linkage, but I have one that works now. Now I need help with the vacuum lines (there are about 6 to 8 lines) and the tuning. I haven't seen an air screw on the carb at all.
Theres a small solenoid near the bottom of the carb. We connected the solenoid to the ignition resistor, it doesn't seem to have an effect whether or not we connect or disconnect it.
