Howdy Rick:
What you're describing is consistant with the early, replacment type composite head gaskets. Unfortunately the maker stamp is usually lost after use and disassembly, so it is unlikely that it's origin will every be known for sure. If it is constructed of a shim metal center with a fiber layer on either side, it is likely a replacement gasket similar to the FoCoMo gasket C9DE 6050 C. These were made by several manufactures. So thickness dimensions can vary.
The newer composites have a layer of teflon type material on top and bottom. FelPros have an orange silicone seal on top of the teflon, for better seal.
The none round bore shape of these gasket is typical of all small six gaskets. The "Bulge" is nearest the intake valve. We have tried to deduct the reason for the bulge, but have no fact based knowledge as to why manufactures felt it necessary.
Gasket bores are typically 3.75" for the OEM shims and 3.81" for all types of aftermarket composites.
These two facts are good reason to not use a gasket to determine head chamber limits for unshrouding the intake valves. Either use the smaller bore, steel shim gasket or, better, bolt the head to a bored and ready, bare block, tip it upside down, reach in through the bore to scribe the true bore shape onto the head deck.
As always, the devil is in the details.
