PCV valve question
Hi guys, this is my first question on this forum. Id first like to say this is a great forum, every one here seems to be genuinely willing to help the rookies (like me), and give good detailed advice. Anyway, my question is, is there an alternative to the PCV valve with a hose that mates the valve cover to the carb spacer? Ive been thinking about putting a 350 cfm Holley two barrel, with a carb adapter (probably from Clifford) on my '67 200CI, in place of the autolite 1100, and I realized that I probably have to remove the carb spacer and mount the adapter onto the log intake. Now, Ive seen some rigs on this site where it looks like two breather caps are sitting on the valve cover. Id assume the second thing that looks like a breather is kinda like a breather only with a PCV valve on the bottom and plugged into the grommet like usual, but Im not sure. Any suggestions or kits you guys might recommend?
