it is a modified stock oil pan and the only one I had I looked EVERY WHERE and I couldn't find one finally I acquiesced and cut this one up
I've gotten comments from "ugly" to "great" to "gitter done"
a local muffler shop did it for me for about $80 another local oil pan "specialist" wanted a minimum of $400 to do it right with baffles and a windage tray but my short block wasn't ready at the time and it really didn't seem like a $400 job to me.
what with a (let's be generous here) $80-$100 Shop labor rates and good planning and cutting I didn't think it should take more than 1.5 hrs to 2 hrs max this isn't a race car either it's a street / strip daily driver that I intend to pounce on "occasionally" hence all the money spent on "high reliability" items like forged Al pistons and two piece forged Con Rods with floating pins. these improvements are for service life and durability not HP so I am partially working in years / dollar instead of Hp/ dollar which may be the wrong way depending on how you look at it but I am at peace with it
first he built the trapezoidal box on the bench using measurements
then he TIG welded the box to the uncut pan
then he cut the pan from the inside out
I don't have a crank scraper because I do not exactly know what the benefit is (Like really what is the benefit b/c I don't know
I know that baffles and a windage tray would have been great but they were outside of my time / $$ line for the time being
True I have the budget but I think my money is better appropriate at the moment seeing as the head and the fuel injection are the last hurdles here.
I am also using the stock pick up so the bottom of the pan is now further from the face of the pick up (is this good or bad IDK) I guess I am fine so long as I keep the oil level up.
I might need to remove it to remove my dipstick tube not sure yet whether I want to use that dipstick hole for a dip stick tube, a turbo oil drain back line, or both.
removal of the pan may allow me some time to modify the pickup up if necessary and it will be easier now that the motor is out of the car hmmmmmmmmmm
we'll see what happens this weekend if the spirit moves me
Keep Sixn'
Dan
