I am putting my head and block together finally. Robert at the machine shop told me I needed to do a mock-up because 1) I have longer valves stems on the che**y valves 2) more lift (.485 in and .515ex) 3) The 360 flat top pistons were about .100 more compression height than the 300 stock 4) the deck was milled .010 and 5) the head was milled .020.
I put some playdough in #1, put the rockers on, put the push rods in. Rolled it over and could see through the spark plug hole that the valve did not even come close to the top of the pistons. I put cam lube on top of the playdough to keep it from sticking to the valve, and that was not even touch.
The question is--I didn't have my lifters "pump-ed" up, will that make more than .100 difference? If so, should I be good to run it? The pistons have valve reliefs. Looks to me like they don't come .500 from the piston, at least?
First Time Sixer, (boy am I provin' it)
Jeff
Jeff
