1) Here is a diagram of how I intend to wire my DSII. I just need a sanity check to be sure that it's going to work:
I'm using the relay because I'm too chicken to tap into the wiring harness behind the dash. I know that it adds another component that could fail... but I can replace a fuse/relay easier than a 40+ year old harness. As I get more confident with my wiring/hacking skills... I'll likely ditch the relay setup.
2) Are there any existing/stock wires that need to be disconnected?
3) I'm also planning on using my Pertronix Flamethrower Coil in this setup... any problems with doing so?
As always, thank you for your sage advice!
