Plug Wires ( Pertronix 1 - Ignitor)
james singleton
Question? What type of spark plug wires are you using with a Pertronix 1 electronic ignition? How about a Pertronix 2 Ignitor; any difference? Also, what brand of spark plugs? P.S. I plan on using a Pertonix's 1.5 ohm Flame Thrower coil; if that makes any difference in the type of ignition wires needed? Thanks, Jim
Since no one else had responded....
My 2 cents on wires......
Nowadays the 'store brand' or standard quality wires are actually decent for a stockish street motor. Only exception would be if your setup runs very close to exhaust manifold(s) or other exhaust parts (like a turbo) which is not a problem with the little ford 6's since all that is on the other side. In those high heat situations you may have better luck with a higher quality and more heat resitant wire set. If you have any oil leaks at all I would make 100% sure you have those fixed before you put on a good set because oil soaks in and kills good wires as fast as it kills cheap ones.
Now if you are talking about a highly moded high rpm engine with a high tech multispark controler then you need to get a high quality wire to make sure you are getting your moneys worth out of the rest of the stuff, and with the thousands of dollars you spent on the rest a $100 for a set of wires should be no big deal.
If you live in a real wet climate where its often damp or wet it may be worth a few extra bucks to get a thicker wire because there is a slight chance that they would be less prone to shorting when wet but if things are that wet the wires are most likeley not going to be the worst problem.
The ford 6's are pretty easy as far as length and I have not had issues with them but for some reason the V8 sets never seem to fit, even SBC's so if I care what they look like I have taken to buying custom sets that come with only the coil end attached, you then cut the other end to length, slide on the boot and crimp the end on. If you are only going to do a set or two you can carefully crimp them with a pliers but if you are doing alot of them spend the money for the proper crimping tool.
Other exception.... if you have a tricked out detailed engine compartment you need tricked out wires to match, same as the hot rod engine...after $1000 worth of chrome $100 wires should not be a big deal.
Summary:
For your application I would most likeley used the cheap store brand ones unless I was feeling rich that day then I may buy the mid grade ones that petronix or your store offers.
I have always liked the quality and price of Standard brand ignition parts, they come in a red box and many stores carry them.
Any good quality supression wire will be fine. If you do like aftermarket/performance wires, You will find that most people that have been in it for a while use either Taylor or MSD wires, and Accel will be less popular (I have had bad Accel wires right out of the box, as well as other racers I have worked with) The Ford Motorsport wires are also excellent quailty, but will need shortening since they don't offer a set specifically for the 200 six. (or for the older style dist caps, for that matter. you would need to switch to the larger cap)
FORDCONVERT & LINC's200, I have a new stock 200cid engine with no exhaust heat or oil problems. I live in S.Calif. so we are pretty dry. I have read previously on this website that some people have used Accel 8mm wires with their Pertronix ignition systems. The reason I was inquiring what type of wires, was the other night on DIY channel they were installing a Pertronix ignition on a 67'Ford Mustang with a V-8 (289cid I believe) and the new wires they were installing (I didn't catch the brand or type) were very large looking wires to me. I figured the higher spark generated from the new coil (a 1.5ohm Flamethrower from Pertronix) and pertronix ign. system requires different type wires than with the stock points? Am I correct? Thanks for your input! Jim S.
It's not a requirement per se, but you WILL get a lot more power with the 8 mm wires, and by opening up your gap. The pertronix and new coil provide a much fatter spark. The old 7 mm wires WILL run.
EDIT: Where in So Cal are you? I'm in OC. =)
Well, I'm not sure I have even seen 7mm wires for sale anywhere in the last 8 years or so, but of course, I haven't been looking very hard for them (actually, not at all :lol: )
The pertronix is just a triggering system, and that coil is maybe 10% hotter than stock. It isn't a miracle-worker.
Any stock plug wires will be fine, but for just a few dollars more you can get a good quality aftermarket set (you don't NEED 10mm wires!)
7mm's are alive and well, got a set on my stang and they seem to work fine, bought them because went to DS2 and have not got the oil leaks under control yet so I didnt want to ruin an expensive set.
For the most part the core (conductor part) of the wires does not change based on the 'size', a 10mm wire could have the same size core as a 7mm. This is not always true but for the most part seems to be. The main reason you get a thicker wire is to try and keep the spark inside the wire and to the plug instead of jumping to something else nearby like another wire or some other part under the hood. The higher the voltage the farther it can jump. Things like moisture make it easier to jump, thats why if you live in a wet climate you MAY have some benifit to a thicker wire. The core of a wire is a fairly brittle and sensitive to heat and other contaminants, a thicker wire would therefore offer more protection to the core. That being said the larger wires tend to be better quality as far as ends boots and other materials and workmanship.
As to coil voltages.... MOST (but not all) of the stuff that you would buy in a average parts store (from stock to a blaster/flamethrower type) is not going to have enough of a differnce in voltage to really stress things like wires in a typical enviorment/ application. There are big differnces in coils but the voltage is one of the less critical issues for most stockish street applications.
You do forsure want to gap the plugs to whatever the petronix says. The coil has less to do with the gap, its mostly up to whatever is doing the control, points, DS2box, hei module, or in your case petronix box/module.
Now if you are running 3 turbos at 8000 rpm you need to do some more research but if you got a stockish engine on the street you will be fine with just about anything you can buy these days.
LaGrasta":2kv7ktpo said:
AutoZone—$30 Accell wires, 8mm.
I dunno.....I honestly don't trust "accels" anymore.
Back in the early to middle 90's when I was BIG into circle track racing, we used to get bad acccel wires, right out of the box.
Accel WERE good at one time, before "Mr Gasket" bought the company out, then the quality control went right into the trash bin. I would never buy another set.
For about $10 more you can get Taylor Spiro-Pro wires, and that will be the best extra $10 you ever spent in your life, because they DON'T go bad and the quality is near perfect. They have the lowest internal resistance of any wire tested (and YES I do test EVERY single wire with an ohmeter, right out of the box) and the jacketing on them is tougher than ANYONE's wire. PERIOD. You can let oil drip on them for years and they are fine, and we have had wires fall right up against header tubes during a race and they can handle it.
I also like the MSD wires, but there are no other wires as tough as Taylor Spiro-Pro.
Trust me, our racing team tried them ALL.
