So, after putting off time and time again I finally sent in my 1100 vaporizor pony carb back to pony carbs for a "refresh". Since March (ish) of 2008 I have done the followng to the little carb:
jets, carb rebuild kit, idle adjust, cold Idle adjusts, blocked off the SCV to use my DUI on manifold vacuum, adjusted the 2nd dashpot, and changed direction of the lever from the gas pedal.
well now (before I sent it in) it has the following symtoms/problems:
can't idle cold without fethering the pedal, can't idle constantly warm (due to the throttle shaft is loose at the linkage making the idle screw miss its seat) and same MPG as before the rebuilt engine (kinda nice though as it has alot more top end)
I mentioned I've upgraded my distruibutor to a DUI and my cam is no longer stock, and planing on higher ratio rockers.
I was told today that tomorrow they are to start work on it,
they will upgrade/replace ALL parts that are not working properly,
I'll get a new 1yr warranty ,
I'll technically receive a brand new carb in thier eyes,
and they will do it all free ,
:wow:
they informed me that since i've puchased it in 2008 (march ish) they have made MANY improvements to the carb and the selection of parts and springs that they put into the carb. I just happened to purchase one that was very early in thier making.
Now, I know I'm counting chick's before the eggs hatch, but so far thier customer service has gone beyond my expectations
Richard
Richard
