OK, I think a lot of folks over here have used ponycarbs to rebuild their carbs, or to get rebulit ones.  The fellows over in the 240-300 forum seem to be hell bent on scraping their old autolite 1101's and getting 2 and 4 barrels.
I have an 1101. Ran good about 6 months ago when this all got started. Now, in the midst of a frame up restore, I am ready to starting putting things back together. In the mean time, the engine/frame sat outdoors with no hood (or cab for that matter) over it for about a month. It did have the aircleaner on. When I pulled the carb to sand blast the engine, I noticed a little water had ran down the aircleaner threaded rod, through the carb and into the intake. Just a little. There is a tiny area of rust on the main valve at the bottom of the carb. Everything else appears fine.
My options are:
1) Put it all back together and see what happens
2) Do a basic carb rebuild myself. ( I am getting pretty good at this stuff!!)
3) Send off to ponycarbs (or someone else you might suggest?) and have it rebuilt.
I would like to have a highly reliable carb when I am done. I want it to be able to sit for weeks/months and fire right up. I want to drive this vehicle from Kansas to Massachusetts someday. It needs to be done right.
Ponycarbs is pricy. They promise a lot. They say they "correct defects in the original design". Do they do things to the carb which make it immpossible for me to rebuild it myself in 10 years? Are they worth the money?
Thanks.......
My options are:
Thanks.......
