The following may be good for a sticky since we get so manu questions on the subject.
Pictures show
* a new port divider
* where it will go
* pics of port divider after much grinding and finsishing with a dremel tool
* port divider epoxied in place (rags were removed when done)
I used Cotronics high temp ceramic epoxy to hold it in place. I stuffed a rag down each exhaust port to keep junk out of the cylinders. I also vacuumed these out and cleaned up the metal with denatured alcohol before I epoxied the port divider in place. I also did some minor grinding inside the exhaust port to remove some old casting slag.
I'll post pics of the header installed soon.
Steve-O
Pictures show
* where it will go
Steve-O
