First of all its running good, with 15W40 oil has 50lbs oil pressure on start up at idle, couple things I wanted to mention.
First, I think the ignition system is putting my old generator to work, will get to high 12V area at 2000rpm, so Im thinkin I should upgrade to an alternator?
Second is the carb, playing around with it, the idle misture screw turned all the way in doesn't stall it, a couple turns out it vacuum and idle drops, so Im thinking I need to change to some smaller jets there?, what are your guys thoughts?
At 1000rpm, my vacuum gauge was reading 15"Hg. About 600-700 rpm area it starts to lope a little, anything over that is smooth sailing, and the engine is very responsive when revving in any manner
Lee
Lee
Revving drops it to 12's momentarily.
