ppp
i have found no better place to buy a cam from than mike and a side note his site is back up
as for which cam to run i would recommend the 264 cause it is a good all around cam
Mike does have the best selection of cams for our engines, for a street mannored vehicle, with N/A. Tho selection is limated, every company is limated with selection, on these engines. Clay smith will grind a custom cam, for any odd application, that somthing special may be needed in, such as Turbo/ supercharging. I have to get a custom grind myself, can't see putting $150 on a cam that will 'work ok' for what I want, when for about $200, I can have 1 ground specific to what I need. will probably be somthing like a 264/254 .450/.445 114* LSA, basic turbo cam.
I haven't personally used Mike's cams, I went with Comp Cam before mike was up and running. I went with a 260H cam from them and I love it. I little bit of lop, but not much on the exhaust. Keeps the low end torque nice. Basically, it's just slightly more aggressive then stock, but it has more lift (.444 with stock rockers).
Slade
