All Small Six C4 vs Toploader 4-speed
Crustang to Mustang
I originally started off wanting a T5 but I know that this conversion requires a custom crossmember and I saw where someone mentioned a custom driveshaft?... Not to mention the price of a good T5 in my area... I already have a C4 so that's an option but I kinda want a manual. So this is my question: Is it worth swapping to a Toploader 4-speed or is a C4 with a shift kit better since I already have the C4?
Manual trans every time, especially with a small displacement NA engine. doesnt matter how good a C4 is, its always got the disavantage of the torque convertor, IMO only good with stock higher torque engines, or for drag racing. C4 and 250 works. The t5 would be nice. Here in Australia toploaders run to around $2500-3500, which is quite a lot. Were lucky we have an Australian made 4 speed about equivalent to a toploader, but much cheaper. Some of the japanese 4 speeds would work, but you need custom bits for that. Dagenham? They should be OK when in good condition.
Personal preferences vary so you're the one to make the decision. A lot of us prefer the manual shift over the automatic, but many others, as evinced by the fact that it's all but impossible to find a manufacturer selling a manual shift car these days.
If money is the driving point behind the decision, a shift kit is the right choice since you don't need the bellhousing, clutch, flywheel, transmission, clutch actuation system, pedal, etc.
Toploaders are expensive - in the same general range as a new T5z. The crossmember for the T5 isn't all that much ($270-ish). I didn't have to change the driveshaft when I went from a C4 to the T5, but others have had to. I don't know what differences in configuration would drive that change but some have had to have the driveshaft shortened. A good driveline shop can do that. If you go with the T5 there's also the choice of which clutch actuation system to use - Ford stock Z-bar, cable or hydraulic.
Be aware of the process of adding a clutch pedal. Watch a video and then look under your dash. I don’t want to discourage you but but just know what you’re getting into. Also the return springs are very strong- difficult to install and remove. If you do go that route, upgrade the pivot point to the bearings as well as make sure the insulators under the ends of the springs are in place ( where the springs pull on the support and pedal ) if not there it will squeak. I don’t know of and hacks for installing those springs. ???
Not ideal gear ratios in a 4-speed top loader for a small 6.
I have been trying to find info to set up a M5OD-R2 (mid 90's Ford V8 5 speed) for a 250. Same bell housing mount as a V8.
$ .02 more :
final drive ratio with both Toploader 4 Spd and C4 3 Spd is 1 :1 to Driveshaft. Late 60's and 70's small block six cars sacrificed performance with tall rear gears to keep RPM's manageable with new Interstate travel speeds.
for 'modern' acceleration needs and interstate Drivability above 70 MPH interstate Cruise speeds an OVERDRIVE tranny is simplest solution.
AFAIH - are there really no automatic-overdrive bolt-on possibilities available for the small block six?. (AOD ?)
T5 overdrive is so far simplest option to upgrade overall modern drivability of small six cars.
'61 250 Tri-Power has 3.80:1 posi gears, with T5 OD can safely drive to the track @ hour and half away at Thruway cruise speed. ( close to 1/4 end speed ! )
the '63 170 Falcon longroof evolved through 3 on the tree to a Dagenham 4 Spd and finally an 80's NWC T5 rebuilt for $200. 4 spd Dagenham had great gearing and 'Hypo" lockout shifter but lacked cruise speed with OEM 3.50 :1 rear gears. T5 gearing can match most six builds and lower ratio OEM rear axles match T5 gearing.
... I never learned to drive them automatics' ...
IMO, measure twice and cut once. I converted a manual 3 speed to a C4, then to a T5. It was a big waste of time and effort but I did it for expediency. I grabbed a couple T5s from a junkyard and in my limited driving before blowing my head gasket, they were fine. (one leaked at the drain plug and it was a surer bet to swap). Also, getting a C4 into a car, for me, was WAY harder than a T5. The T5 was (almost) fun.
Better for what do you have specific performance goals. Like 0-60 or top speed requirements.
I am currently considering turbocharging the 250 if that info is of any use in this discussion.
I am also pretty sure that the 8" that I have has 3.55:1 gears that I will definitely be using for now. But I am thinking of putting 3.80:1 gears in when I get the chance if that is still a good option.
My donor car does still have some of the clutch assembly still on it as well.
Interested if any 250 with AOD's been done -
info on AOD appreciated - is AOD stand-alone use or need ECM ?, ratios and ratings vary? .
same 5.0 Bellhouse FW/FlxPlates? . FW tooth count ? Output spline count ?
thanx
thanx
I think that the biggest problem is that 250ci already has a hard time putting decent power to the wheels a nd the parasitic drain of the AOD isn't gonna help matters.
For a daily driver, maybe. Street car, probably not.
good to seethe AOD Overdrive automatic is somewhat an option-at least for the 250.
" With 3.55 gears, the engine turns 2350 rpms @ 70 mph. Gas mileage ranged from a low of 19.2 to a high of 27.7 mpg. On average, I got 22.5-23.5 mpg in daily driving."
Impressive ... .
I’d absolutely go with a manual to keep all of the power the engine makes. I think with a 250 you have the ability to use a V8 bell housing and bolt a T5 right to the back of it without any adapter nonsense. You’ll need a cable or hydraulic clutch which I think is going to be better than the Z-bar linkage anyway. You’ll need a slip yoke for the drive shaft that fits the output shaft but a 65/66 manual trans driveshaft should be the correct length without modding it.
On the subject of driveshafts, the 92 - 01 Ford Explorer 2WD came with an aluminum driveshaft that measures 50”. Im keeping an eye out for one for my car. It will need a conversion u-joint for the differential but it should fit the length perfectly and be a better balanced and lighter driveshaft.
$ .02 more :
Yes sir you and I agree about the lamentable lack of a automatic od trans choice for the 200. It will not be a performance choice for typical Mustang/Falcon 200 cars but they are light cars and having the od gear would make them more freeway capable especially more so with a modified 200. Not really big enough market I suppose for a company like MD to make adapters. I have had very positive experience with the A4LD trans in my Cherokee but they also were also used in Ranger 4 cylinder trucks and v6 Explorer. Would require electronic shift control also I believe. Ford Ranger A4LD Automatic Transmission - The Ranger Station
"I think with a 250 you have the ability to use a V8 bell housing and bolt a T5 right to the back of it without any adapter nonsense. You’ll need a cable or hydraulic clutch which I think is going to be better than the Z-bar linkage..."
no reason the T5 cable bellhouse can't be used on the 250 with the OEM Z Bar Push linkage, simple fulcrum TO arm adapters are available.
'Maverick 250 3OTT to T5 with OEM Z-Bar and T5 BH with fulcrum pedal push-fulcrum TO adapter ( cable mount boss sawed off' )
hav efun
Unless you are fortunate to have the last revision to the 200, the big bell I think it was called. You could adapt that to the sbf bell.
Looking at your link for the A4LD trans, it does not require an electronic controller until the unit with E as a suffix. They all have electric torque converter lock up. Activating the TC lockup is a simple one wire procedure, it would be manually controlled by the driver. Even on the E4OD truck trans, I have a simple toggle switch on the turn signal lever, one wire from trans and ground it via the switch, the TC is locked. Also did the same on a Chevy 700R4 way back when.
So a A4LD (without the "E") is the best of both worlds- mechanically operated gears, no expensive controller and wires- yet still has lockup TC.
Posted as FYI for the OP
