Pre AU to AU, difference in offset
2nd.gunman
Anyone know the difference in mm's? i need some wheel spacers to fit the territory rims to the XA ute. i think preAU to AU spacers will work, i need 30mm. Also anyone know where i could get some with imperial threads.
BA backset 133mm
EF backset approx 88mm
I'm chasing some adapters from the Californian mob "Motorsport Technology".
I do. We got them at work. Can have any pcd to any pcd eg 4X108 into a 5X114.3 and come in 3 or 4 widths.Made out of alloy at about $70+. New studs are fitted so if you ask nicely you can get 1/2 inch thread with is Ford and kep the Tezza nuts. Now that last bit sounded wierd!
2nd.gunman":2dt3b8qm said:
is that $70+ each or for a pair? where do you work
Yeah they average at $70 each all depends on the amount of machining needed.
I work in a tyre joint in Adelaide. If you cant find anyone in Brizzy that does em PM me and ill see if the boss will send them out to ya.
You should only need 2 spacers for the rears. A ute thats a regular to work had territory rims on it 16 inch with the caps that knock over the nuts. Not sure if they are the same offset as the alloys but i image they would be. It was a XF ute, they sat fine on the front and a little in on the rear and looked bloody good IMO. Steve
definately need spacers front and rear, they are the 17 inch steel wheels with 235/45 tyres. hits the upper arm on the XA, i tried them on both my XA and XE utes couldn't get them on the XE as the centre hole is just fractionally too small. perfect size for the ealier XA hub.
found a place on E-bay, set of 4 for $200 but don't know if there imperial or metric studs.
$200 is a good price. You can change the studs yourself all you need is a hammer and some new ones, maybe some locktight. Good luck with it too, wouldnt mind seeing pics when your done. Be the first XA ive heard of with tezza rims on it
