Can any one here confirm the orgin of the early Aussie XK-XM diffs and Chrysler 225 diffs before the advent of the Borg Warner 78? Ratios ape the US Falcons, Plymouth Valiants, so I'm pretty sure they were imported diffs from the States, but anyone else know?
4.00 :1 diffs from the early 60's utility models (Ranchero to you) were used in Norm Ormbys legandery 1970 Australian Drag Race winning 400 hp 351 Falcon GT. It had no limited slip diff, and he used a fly-off handbrake to control wheelspin on launch. It ran a Toploader gear box!
Heres a range of crownwheel diameters which Ford Austalia used, and some weights and torques:-
Cortina 6 (200/250, log head and cross-flow) Early cars, 7.6" diff, 2500-2700 pounds from 1972 to 1980. These do wheel stands behind 302 V8'S!
Then in 1981-1983, Cortina Sixes got a smaller 7" diff with the 185-215 lb-ft cross-flow 3.3 and 4.1's, which were 2700 pounds. Marginal
Falcon Sixes 1966-1993 from early 170's to the last 3.9 OHC's with 155-255 lb-ft and 2700-3300 pounds got 7.6" diffs. Held up fine.
Post 1993-2003 sixes and post 1972-2003 302V8 Falcons/Fairlanes/LTD's got 7.785" diffs in cars ranging from 3300 to 3800 pounds, with 255 to 369 lb-ft. Bullet proof.
351 V8 Falcons/Fairlanes/LTD's from 1969-1979 weighed up to 4000 pounds and got 9" diffs.
