Eg. 1 Take a 351 Cleveland, such as a 4V HO or Boss, and you find the best street power with a single carb and passable economy is a 750 cfm Holley or Spreadbore. If the engine power peak is at 5800 rpm, and has 85% volumetric efficency, then the engine needs
((351*5800)/3456)*0.85), or 500 cfm of carby flow.
750 CFM IS WAY OVER THE LIMIT!
from line 29 on
http://fordsix.com/forum/viewtopic.php?t=7015
you get the following info.
29|#4150-|750|4-bbl-|1.6875-|1.3750--|2.9700|22.7-|1.6875-|1.3750-|6.216---|~290ft/sec|229|469|
The flow is 750 cfm, but the airflow is actually 290 feet per second at wide open throttle with 1.5" Hg of pressure drop.
But the engine only needs 500 cfm to get maximum power. That pegs the actual air speed down to 193 cfm.
What happens if we place a 600 cfm Holley from a 5.0 HO 4V Mustang, what's the air speed then?
20|#4180-|600|4-bbl-|1.5625--|1.2500--|2.4540|25.0-|1.5625-|1.3125-|5.1600-|~279ft/sec|183|375|
Well, at 600 cfm, there is a 279 ft per second air speed at a 1.5 "Hg flow drop, or 600/500 less air flow. That's 232 feet per second.
See the pattern? Plot your actual air flow from the formula used for carby sizing, and then grab whatever canditate carbs or combo of carbs from my chart, and adjust the carb choice untill you get between 200 to 250 ft/sec air flow.
