I sat my pump in oil and wound it over by hand untill it started to come out the top then let it drain out then bolted it up.Then use the drill and and shaft method. Priming the pump first and getting oil pressure this way is way better than winding the engine over on the key,even if your crank has been coated in assembly oil there will still plenty of revolutions of the engine with out oil feeding the bearings.I used the same method as Gassed250 ,its always nice if you have enough spare dissys to go round cutting bits up to do the job. you pump up and screw it into the oil .Get a cheap mechanical capillary style gauge,theres some real budget ones out there and at least you can see what sort of pressure your getting before the light kicks in.A brass T fitting with the switch in one end and the gauge feed in the other works well. The cheap nasty gauges we have over here go for about $10-$20 bucks.
Hope the start up goes well.
