Pro charged 300
Pmelsness90
Finally got around to getting this finished up break in went good. Holley sniper picked up right away no problems. Get a few additional pulleys to figure the boost out and off to the Dyno to see results.i left the inner cooler off the run stand. I feel it's going to make some pretty good power not sure when it'll go on the Dyno but I'll be sure to post results.
Nice job. Like your ventilation system, can you tell us, or show us, what we cannot see in the pic ?
The puke tank on the side was pretty easy I just used a 3x3 square aluminum tube. The 3 mounting holes on that side for the valve cover I did long studs so the tank mounts to the valve cover. As far as the valve cover I had 2 pieces of aluminum that I had machined down with a shoulder and tapped it to 12 an oring boss. I glued the aluminum to the valve cover and put 12 oring boss to 12 an fitting in it made some hoses to connect them, I added the tank because I didn't want oily breathers making a mess and our local track requires a puke tank on forced induction setups.
No it's water temp, I didn't want to put the temp sensor in a thermostat housing. My Holley sensor is in the factory port on the block that sensor is for the Dakota digital.
