I have an exhaust leak at 6th cylinder. Apparently, the threaded hole in the cast iron head is stripped or significantly damaged. The previous owner put a 5/16 - 18 bolt through the hole with two nuts on the manifold side to "engineer" a repair. Is there a tried and true way to repair this at least in some semi-effective way? Thanks for your help!
