Pulley Advice
Inline6Merc
I've slowly been working on my supercharger set up and I was wondering about pulleys. On the crank shaft, there is a single V groove pulley (harmonic balancer). On the supercharger there is a serpentine pulley. I was wondering weather or no to bolt a serpentine pulley to the stock harmonic balancer or find a double groove pulley for the crank and run a single V belt to the supercharger? If I run a serpentine pulley on top of the harmonic balancer, will that unbalance everything? I would appreciate and comments.
Thanks,
Curtis
it shouldn't unbalance anything by stacking a pulley on it.I would prob look for a pulley in the bone yard off a water pump on a late model with the right depth to it for your balancer/setup. simpley redrill for the balancer and you should be good to go.
