I can help out a bit here, for NHRA Stock Eliminator you must run specific "stock" parts. There have been some exemptions such as aftermarket con rods, electric waterpump drive,elec fuel pump, any ignition, stock lift but unlimited duration cam, etc.
The head is allowed a 3 angle valve job PERIOD! No porting, polishing, grinding, back cutting valves, etc, whatsoever. Same as intake, as cast, no grinding to even remove sand flashing. Must keep original carb for year of engine with no mods which will increase airflow.
With extremely tight rules, you must flow a bunch of stock heads to pick the best head. (flow differences due to casting or mold condition) Guys will have BOXES of new pushrods to get 12 (or 16) EXACT SAME LENGTH pushrods.
You can only lighten up the remainder of the rotating assy to the lightest. In other words, weigh all the pistons and rods, and balance the others to match the lightest. You must have at least one stock, unlightened piston. As far as skirt mods (or ring width,placement,number) the pistons must remain stock or an approved aftermarket replacement. (there is a approved piston list)
My 2 cents, run the strongest pushrod you can afford (due to the length) to minimize deflection and loss of lift. There is no approved rod or piston for a 71 so your stuck there, I would change to a shorter pin and spiro locks which would be a bit lighter then rebalance (yes this is legal)
The rocker stand trick is good, but I wouldn't get bent up about lots of oil pressure, any more than 7-10 pounds per 1000rpm is wasting hp. You have a scraper which is good, you want to cut down on windage. Are you running royal purple oil? Expensive but they pay contingency and more importantly they reduce drag. (and run a light grade, talk to them they will recommend what oil to run in your application)
Cam: I know your running a stocker cam now, talk to bullet or comp cams and see if there is a better one for the new parameters. Different duration/lobe spacing/centrelines. Are you running shubeck or Sherman lifters? Rpm potential there with the ability to run stupid high seat and nose pressures. What are you running for a damper? The stock cast ones can be dangerous above stock rpm, not only for the harmonics they don't cancel out, in comparison to a rattler/etc, but also due to them possibly exploding from centrifical forces. 6000-6200 would be all I would want to spin up any engine with a cast damper. (or dampner for some of you, Lol)
One last thing, I don't know what your running for headers, but a properly tuned (length and dia) set will certainly help get up there, and make more power at peak. Talk to Greg Fulk over at classracer.com on the tech board, he's the guru for inline sixes, fours or anything that's an oddball unknown combo.
Lotsa luck! (I knew you'd keep the six instead of a crate 302
