Hi everyone! I hope all you can understand my post, I'm a little bad with my english (my apologies and please don't blame me)
According to this:
The improvements that I'm looking for, are:
In Mexico it's a little more difficult to get upgrades, parts or good works but I'm trying my best hehe
How many HP I can expect from my upgrades? what recommendation do you have for my project?
Also, the next year I'll try to supercharge my engine with the thunderbird SC supercharger hehe (if I want that i should avoid to mill the head right?). Of course this will be the only one ford straight six 170cid supercharged from my country haha obviously if i can do it.
Regards from Mexico City.
According to this:
Summary: Here's how to figure out what size the block is. Identification can be made with a quick glance at three items on the motor, the water pump, number of freeze plugs, and the block code (found on the road draft tube mounting boss). The only trick is determining the difference between a 170ci 4 main and a 200ci 4 main, if there is no block code, as both engines had a three bolt water pump and three freeze plugs. The only way I know of for sure, is to verify the bore size. If I learn of another method, I'll let you know.
250ci -7 main: 4 bolt water pump and 5 freeze plugs.
200ci -7 main: 3 bolt water pump and 5 freeze plugs.
200ci -4 main: 3 bolt water pump and 3 freeze plugs.
170ci -4 main: 3 bolt water pump, 3 freeze plugs, and a "T" code (or no code).
144ci -4 main: 3 bolt water pump, 3 freeze plugs, and an "N" code.
(Note: Early 144/170's had a 1/4" distributor drive, later 170's had a 5/16" drive).
- 2V Conversion on my stock large log manifold (I have a 1.75" diameter log on my head, with the next casting number: C3DE-6090-DX5 it's correct?)
Holley 350 carburetor
I hope I can made a full port, and 3angle job or at least port-matching on the exhaust
Mill the head .060"
Camshaft swap: CSC-264-10-HSP with 302HP springs
I have a stock Adjustable 1.5 Rocker Assembly (no changes here )
Stock valves (or what i should do)
Headers
Arvinode dual exhaust system
Pertronix ignition upgrade (In the future DSII Ignition or DUI Ignition if i can)
Transmission swap (Toploader)
Oilcooling via sandwich adapter and fluid cooler, on the oil filter
