question for jack !
when i,m right you did put on some 94> wheels onto your car with some spacers in front , i did want to order some wheels and did questio about it if there would fit , this was the replay
1007-J178 Bullit wheel in Charcoal for $155.00 per wheel. They are
ONLY
available in 17"x8". I can ship international but I would need your
address
before I could give you an accurate shipping quote, but you can expect in
excess $450.00. The wheels will fit the rears fine. Bolt pattern and back
spacing is the same as a 94+. On the front, the 60's mustangs had an
upper
control on the front whereas the 94+ cars do not. If you run the rims you
want on the front it will hit the upper control arms, so you will need to
run wheel spacers on the front to get correct clearance from the back of
the
wheel to upper control arm. To make sure that the car is uniform all the
way
around I would suggest getting the same size spacers all the way around.
I
sell spacers, but the ones I sell are not thick enough. If you have any
other questions, write me back.
Grady
Harrie, I have bolt on adapters that provide the proper spacing for the 94-03 Mustang wheels.
The front ones are 1" (25mm) and the rear are 1.25" (32mm). You can fit the 17x8 wheels using these and the 245/45-17 tires fit the 65-66. I have 16x7.5 wheels now with 225/50-16 tires, but I have tried the Bullitt wheels from a friend's 2002 GT and they fit fine.
aaahhhh great , so there wil fit !! , where did you order the spacers ?
i,m just into order them bullit wheels , would be great to order the spacers too, so they can be right bolt on !!!!
I bought the 1.25" spacers from Spidertrax. The Jeep has the same bolt pattern. $125 I think.
The 1" spacers I bought on Ebay for $60.
is there anything that i could use to covert to 5 lug. I mean like a little adapter, nothing major.
