For about AUD$400, I have two options for my project.
1. A triple core radiator about 16" high, 20" wide, modded for the small outlet sizes. Slight trimming is needed to install it. Frontal area approx 320in².
2. A four core radiator about 16" high, 18" wide. Bolt in, frontal area approx 288in². This is 90% of the frontal area for Option 1.
Which will actually give the best cooling, if both are brass 14 fin-per-inch cores? Assume that throughflow is potentially equal on both. Manual tranny. The other curve ball is that I plan to fit aircon...
Thanks, Adam.
Thanks, Adam.
