xrwagon":9dvl7exw said:
ok mine has leaked a drop or two most weeks, has been getting worse since racing it etc, what can i expect? Is it robbing performance? Is it more of a pain in the but to fix, as its a little oil etc, it has sprayed the under carriage and dropped a puddle. What brand should i use and, should i remove the whole engine and box?
No engine removal required. You've got the old rope seal, so its tough to get em out. Replace it with a neoprene Felpro or similar. Sizes vary, there are a different lenghts and sections, and some are cut to fit, which can be a pain. A note only for us AuNZies...the little 200 used a 2.75" pitch six bolt center flange with a 3.625" crank out diameter flange before the big tall deck change to the 250 based block in 1971 Aussie FoulCans. Don't let some counter wally give you the later XY/XA/XB non cross flow 200/250 item.
To get the old rope seal out, you only need to safely get the car high enough to drop the trans, sump, and end cap. You should be clear of the drag link, but if needs be, you can jack up the engine by loosening the mounts, but still keep the engine in the car.
To get the seal out, you have two options. Option 1, use KD Tools 492 Sneaky Pete Oil Seal Remover/Installer
http://www.sjdiscounttools.com/kdt492.html
Oil Seal Remover and Installer
Removes and installs upper rear main oil seals with engine and crankshaft in place. Works on both wick and neoprene type seals. "Chinese Finger" type grip won't slip from seal during installation. Set includes wick seal remover, installer, guide funnels, pusher, offset trimmer, and neoprene seal punches.
Option 2, you use
Bhigdog's
http://forums.aaca.org/f120/sneaky-pete ... 38028.html recommended piece of 14 gauge copper wire pushed through the end 1/2" of the rope seal. Have someone turn crank as you pull rope through. The new seals seem to be made of Kevlar or other "can't cut" material. A knife or razor blade can't cut them. A scissor will if you get the seal well back in the blades and work it through. This can't be done with the seal in place under the crank. What will work is to cut it off with a dremal abrasive wheel but be sure to put a thin shield between the seal and crank or you will nick the crank for sure. A feeler gauge works good.
After all that, apply a replacement two piece neoprene seal
Taking out the rope seal
https://www.youtube.com/watch?v=JF-BE7o5GUE
Taking out a stock neoprene in a 66 289, and the replacement with neoprene,
https://www.youtube.com/watch?v=7r7GiliZj48
The two piece seal is around. FelPro or National 3909 or Timken 3909 seal replacement. It suits all early 60-70 Aussie I6's and every 60-83 US small sixes with a shaft diameter of 3.625" and presses into a bore of 4.24"
FEL-PRO BS30135
http://www.rockauto.com/catalog/moreinf ... cc=1333370
or Felpro P30135
http://www.ebay.com.au/itm/200-Ford-Six ... 1448123339
You offset the two piece seal and use Bills
wsa111 famed Lexus sealant that sticks like sh!+ to a blanket.
viewtopic.php?f=18&t=37888
addo":9dvl7exw said:
Is it still leaking out the rear main? You could try the technique wsa111 espoused, where the seal ends are offset by about 1/32" from the block/cap interface, and they're given the lightest dab of Lexus "FIPG" sealant.
I'd also wonder about trying to get a good dose of moly grease into the seal groove before bolting up, and also dry cranking a few times to spread the lube about before your motor fired.
Although it's backtracking to some extent, got to be better than a rebuild - if that's not due yet.
Cheers, Adam.
