I've been reviewing the Ford Six Performance Handbook, and in the Porting section I saw the recommendation to pull the intake manifold end plugs to work the outboard intake ports.
I've done the search here, but haven't seen anyone write about having done this, and if replacement plugs are difficult to source. I'm considering working a head over to remove casting flashing and do a conservative bit of porting and polishing. It makes sense to pull the plugs but I'd like to know before hand that I could get a set that would fit properly when I'm done.
Has anyone done this, any tips, and what plugs did you use to close up the log when you were done? Was it really helpful?
Thanks!
Thanks!
