IVE THOUGHT ABOUT THIS MANY TIMES, AND ALTHOUGH i HAVE A 250-2V HEAD AVAIALABLE, AND PLENTY OF ohc SIXES SHOULD i LIKE TO GO THAT WAY, THE OLD CUT OFF MANIFOLD IS CURIUOS.
IVE THOUGHT THAT CUTTING THE HEAD WHERE THE BLOCK FINISHES SO THAT THE WHOLE EXHAUST FLANGE ETC IS REMOVED WAS THE WAY TO GO. THEN YOU WOULD HAVE TO ATTACH A FLANGE PLATE TO THE HEAD AND MAKE INTAKE AND EXHAUST MANIFOLDS FROM THERE. THE ONLY TIME IVE EVER SEEN THIS DONE WAS ON A 221CI AUSSIE SIX USED IN AN ANGLIA SPORTS SEDSN, IT HAD TRIPLE WBERS ETC AND WENT REALLY WELL. HOWEVER ITS A LOT OF WORK, BUT HAVING SAID THAT ID LIKE TO GIVE IT A GO, BUT I DONT HAVE A HEAD TO WORK WITH, I DO HAVE ACCESS TO A MILLING MACHINE AND COULD PROBABLY DO THE WORK MYSELF. FOR YOU ID RECOMMEND THAT YOU GET A 250-2V HEAD OR THE ALLOY CLASSIC INLINE. OR IF YOU WANT TO GO REALLY HARD GET AN AUSSIE OHC ENGINE. IVE LOOKED AT COWICHAN BAY ON GOOGLE EARTH AND YOUR A LONG WAY NORTH THERE, ALMOST DIRECTLY OPPOSITE ME IN PERTH.
ANYWAY BEST OF LUCK AND KEEP IN TOUCH
A7M
PS IM NOT SHOUTING JUST ENGAGED CAPS LOCK BY MISTAKE
