Rocker Arm Ratio Question
I currently have an adjustable rocker arm assembly that has a ration of 1.5 on my 200ci. I'm using a cliffy head, cam, heavy duty push rods and the like and am at 110 RWHP. I keep hearing that I should go to a 1.6 ratio rocker assembly and am wondering what if any data there is to support one versus the other. FSPP has theirs for $415 and I think it'd be worth the try if I am able to gain any noticeable gain from the valves, etc. opening up quicker, longer, wider, etc. Anyone have thoughts on this?
Dave
Howdy back Dave:
The math is quite simple. If the lift on the cam lobe is .300" a 1.5 rocker arm ratio multiplys that amount by half or .300" X 1.5" = .450". IF you were to change to a rocker arm with a 1.60:1 ratio lift would be .300" X 1.6 = .480" OR a difference of about .030" lift increase. .030" is about the thickness of a match book cover. You can gain that much by backcutting the valves, which also lightens them. Lighter is better.
Increased ratio lift does add stress to the whole valve train system, so the question should be can your engine use the extra lift or is it just wasted motion? Most log heads cannot effectively use lifts much beyond .400". The 1.6:1 ratio does not open the valves any sooner or change closed duration. It will slightly alter durations at .050" of valve lift because it has to open the valve farther in the same amount of time.
Most performance cams have adequate lift using the 1.5:1 rockers. Lift is lift as far as air flow is concerned. You job is to figure what you need and how best to get it.
Other advantages of adjustible roller-tipped rockers are; less friction, less side stress on the valve stems, hydraulic lifter pre-load adjustment.
Full roller rockers, rollers on the shaft and on the tip, offer less friction at all contact points.
Either roller tipped or full roller rockers are available in 1.5:1 and 1.6:1 ratios.
For high rpm work and sustained high rpms roller rockers should be considered essential. They will likely not add much in HP. They will add reliability and endurance. AND they are super cool. It's too bad they have to be covered up with the valve cover.
The downside to either is $$$$$.
I prefer to get the increased lift built into the cam and use 1.5:1 rockers. However, if I were not changing to a performance cam then 1.6:1 rockers is an easy, but not cheap, bolt-on increase. Of course you have to have the complete coordinated package to take advantage of the lift increase.
If you decide to go for the 1.6:1 rockers be sure to check for clearance between the bottom of the retainers and the valve stem seals, and that the valve springs do not bind.
That's my two cents, for what it's worth.
David,
Thanks for the insight on the lobe, ratio, etc. I checked the lobe on the 264 cam and it's .296 lift it's multiplied by 1.5 so equal to .444. If I go up to the 1.6 then it's .473. So to clarify the Ford 200 won't make much use of either lift quotient over .400 and there'd be no real benefit to going with the other rocker assy. I have also ordered another copy of the handbook since I lent mine out and never got it back. I have a friend with a '65 Ranchero and he wants to make sure he's using all those nice little tuning tricks to ooomph up his stock 170.
Dave
