The motor was recently rebuilt. I installed a larger cam (270-ish duration) and the adjustable timing set. The timing set is at 2 negative waiting for the triple one bbl set-up. Right now a YF carb from a 240 truck engine sits on the re-worked 250 head. The car idles great in park/neutral. I balanced the pistons/rings/pins to within 1/2 gram. After I put the car in drive the engine shakes and is rougher than a corn cob. I think due to the longer duration camshaft and later closing intake the manifold vacuum is about 14 in Hg. What are the possible causes of my sweet little running engine to rebel when placed in drive?
