New Lime 69
Active member
Recently I pulled the head on my 250 since I believed I had a headgasket leak. This assumption was based on a gradual dissapearance of my radiator fluid although no bubbling in the radiator and no overheating. Well, I pulled the head and all looks fine, except two of the bolts that bolt the head down are rusty. If you are looking at the engine from the front of the vehicle, they are the ones on the left side closest to the exhaust manifold. As I looked things over more, I saw that the bolt hole in the head was rusty as was the threading in the block. Since there are no water jacket holes on that side of the engine (between head and block through head gasket), where is the water coming from? I suspect there is a small crack in the head or block lesading to these holes, but I cant tell where.
So what do you folks recommend? This is a rebuilt engine (7 years 45,000 miles). I am inclined to use some sort of sealant on the threads and the head of the bolts and keep going... Bad idea??? Any help would be appreciated.
