mysaviorreigns....you *have* read the DuraSpark conversion sticky at the top of this forum, right?
You can go 2 ways with a DS conversion, DS1 or DS2. I *really* like the DS1 distributor because you can use your existing points-type cap, rotor, and wires, plus it looks stock/period/stealthy. DS1's were made for +/- '75-'76, then Ford went to the DS2. The only thing different from a DS2 is the huge dizzy cap/base and different wires, parts houses spec the same dizzy for either app. If you go with the DS2, you'll need new (different) wires from the points-type ones you already have.
If you want a new/reman distributor (not a bad idea) and module;
www.partsamerica.com (aka Advance Auto)
Vehicle: 1975 FORD MAVERICK
Engine: L6 3.3 Liter 1BBL
Cardone Remanufactured Distributor, Part Number: 302690 = $52.44
GP Sorensen Ignition Module, Part Number: EL104 = $20.98
$70 + whatever bits of wire you need to hook it up, which shouldn't be much. (and I'll bet you can call around and find better prices)
If you want a DS2, I'd hit a wrecking-yard first, iirc there are several in nearby GrandPrairie. See if you can snag everything - dizzy, cap/rotor, plug wires, module, and as much wiring as you can get. I wouldn't pay more than $30 for the lot, hopefully you can pick-n-pull your own for maybe $10-15 (cash talks!)
OR you can use a GM HEI 4-pin module to fire the coil, ask for:
GP Sorensen Ignition Module, Part Number: EL102 = $15.98
(if the partsmonkey wants to look up a car, tell him you want a module for a '76 Buick Electra w/ 455)
