setting time
250mav
i think i need a quick "idiots guide"
ive never done it on a ford 6 so i thought i'd ask
its on my '76 250 mav with the stock electronic ignigtion and h/w 5200
am i going to need a tach to do it right or just hook up the gun and go?
thanks
A tach is handy but should not be required.
Nothing unusual about the 6's that I can think of.
Why are you messing with or checking the timing?
when its cold it tends to miss and backfire through the carb :shock:
it goes away once it gets warmer but it still feels like its not hitting when it should.
so i just hook up the gun and see if the mark on the balencer is lining up with the timing mark?
i have to disconnect the vac advance and plug up ts intake port too right
Full props to Bort62. You can also get a good result with a vacuum gauge. Hook it to manifold vacuum right below the carb and turn the dizz until you get max vacuum. Then set the idle to a reasonable level.
Then, if it pings on hard acceleration, back it off just a touch.
That works, too.
ok, thanks guys
most of the ignigtion is new components anyway, just never got around to the actuall timing
ive got a few projects on the shelf this weekend, hopefully i'll get to that 1 as well
thanks 8)
