There has been a fairly complete discussion on port area and air flow, the triple carb log adaptors for triple 1-bbls aren't nearly big enough, and Ak Miller was WAY ahead of the pack.
http://www.classicinlines.com/HA1.asp
I'm pro multiple carb, by the way, but I don't have my head up my butt thinking they are ever easier to service than a properly designed solid state piece of Detriot engineering. Dearborn has learned way to much to ever go back to multiple throttle body EFI for main stream cars. It still has a place in the halls of a wicked I6 or V8, but port on port induction has to have a single point metering system to be reliable in service, or some means to correct it if a physical setting falls out of range.
I've often thought about why a righteous conversion 200/250 kit didn't prosper, and it all comes down to 1.service,
2.throttle syncronisation,
3.hood clearnace and
4. meeting the US Clean Air Act.
A lot of the cool 60's stuff, the Holman Moody, Hilbourne and Ak Millers multiple port innovations couldn't be sold even through Ford Total Performance because the systems were too complicated, and even the best of Detriots production engineers couldn't package them to cope with heat soak, emissions and hook and ancillary clearance. I'd guess the cost of engineering I6 engines for EFI or multiple carb was out of proportion to a hot small block with a killer set of canted valve heads and a big 4350 Autolite. That's why the planned injected Mustang 250 engine which was promised never hit the show rooms....cost, packaging, and emissions. And just the 2-bbl 2v M code Aussie 250 six could hardly fit under the hood of a 69 Stang, even with the industry record of the thinest air cleaner ever at Cobra tri-power matching 1.5".
In fact, the historicals on the American multiple side draft I6 read a lot like Detriots 2 and 4-bbls verses whatever...like the ill fated Inline Autolite, the triple Weber i6 perfromance machines like the Vantage DB6 and DBS Astons with 314 to 325 hp were no match for a simple Boss 302 or 351C HO 4v. Simpler, cheaper easier V8s. The early EEC3's and then once EECIV port injection hit town, any I6, even with 24 valves and Bosch D injection was a lame duck. History shows one throttle body, one carb, one mutiple distribution point will be easy to syncronise, and with port EFI, there is a 19% power boost on average and a 7.5% torque boost on average over a 4-bbl I6, and as much as 25% and 10% torque over a 2-bbl
(1980 Mercedeas Benz 280S verses 280E w123 175 hp 4-bbl vs Bosch K Jetronic 216 hp, and 1985 2-bbl Falcon over EFI EEC4 Falcon, 131 hp vs 164 hp)
A good single throttle body port EFI system always kills any other carb system, independent runner or whatever, for service and reliablity, that was Fords saving grace in 1984 to 1985, when suddenly, 5.0 and 2.3 port fuel injection became cost effective, and warranty claims dropped while HP went up. It was just expensive to set up and engineer. For Ford, a 4.9 port EFI truck engine was more relaible than any other engine combo except the EFI 5.0.
And why did Ferrari, Lamborghini drop multiple carb Webered V8's and V12's in 1980's...because they wouldn't pass the 50 000 mile serivce requirments for emissions. So suddenly Bosch K jetronic systems got put in, and we have a loss of 25% power right off the bat in most cases.
If self service is your thing, you can spend as litle as 400 US bucks and get motorcyle flat side Mikunis in 3, 4 or 6 carb set ups, and get a 100% 2 time the rear wheel hp conversion together if you do your home work.
Ultimately, the big problem was always industry resistance to the side draft constant depression or varaiable venturi carb in any form. It could work superbly if left alone and the floats and jets were the only item of replacement, but the normal process is for people to fiddle with them. In the days of 240 and 260 Z's Datsun made the best carbs ever, the Hitachi 150's, and still people mucked around with them, a created some stress. As soon as the proper fully electronic 260Z, 280Z and 280ZX/ZXT's came out, reialblity sky rocketed. The English persisted with triple side draft SU carbs to 1969, then tried quad Stromberg Zeniths CDS175 carbs on the V12, and triples on the Aston Martin till 1972, then Jag ditched the twin carb XK engine set up in 1977, and whent EFI like Datsun. Aside from the control unit failure due to heat, the set-ups were dead reliable.
Proton, Toyota, Mitsubishi and Suzuki got Aisain to supply a special 46 mm 265 cfm Downdraft Variable Venturi carb after fileing for patent in 1984. It worked brilliantly, but some versions in the 1988 Tercel were defective, and that fairly well scuppered the carb for the US, although it is the best of its type, and way underated. Its still in production as a new replacement carb for the 14 variants the four Asian companies used it on, and it has no problems with hood height or fuel surge or sub standard quality like some carbs, and, unlike the Mikunis, its been a car emissin carb for the 17 years it was produced.
The side draft SU H series (HS6, HD6, HD8, HIF 44/HIF6/HIF7) and Stomberg Zenith (CD150/CD175, CDS150, CDS175 ) carbs fit fine, although they don't pacakage well with air conditioning or EGR emissions gear. Better still are some flat side Mikiuni RS 38 or RS40 carbs
And my Aisan VV carbed prototype log, which fits the Classic Inlines head, the log head, and allows full emission control EGR and air conditioning to fit, fits the tall 250 engine under the Fox body hood. It works best with the later iron exhasts, the aftermarket industry still hasn't gotten its head around emission with the 3.3 and 4.1 combos yet.
And the 1984 to 1990 twin carb Toyota Corolla 1452 cc 3A HU intake and carb set up I based it on.
http://tercel4wd.com/viewtopic.php?f=8&t=1383
http://www.youtube.com/watch?v=OMD0praeb3g
