fastfalcon_19":3k5yhep4 said:
....I am going to take it off right where the log meets the individual ports that enter the head. I am hoping to fabricate plates that can be welded flat against those ports with the proper bolting locations for the cvk carburetors....
I don't want to say that it can't be done but I want to forewarn you of the 'joys'(read: quite possibly the most stressful moments of your welding life) of welding cast iron. I don't have much experience welding on heads but I've some experience welding cast iron and it's a material that does not like the stresses that are caused from welding. Not to mention you're going to be welding in a circle around each port which is going to cause a lot of stress in multiple directions.
There are particular procedures involved with welding(pre-heat, peening, post weld heating/cooling, yeah i said heat/cool...it's a real PITA) cast iron that do not make it easy to complete without the proper tools and even if you follow these procedures, everytime you make a weld you are rolling the dice on whether or not it will be water tight.
To give you an idea of how long it takes, I repaired a turbo manifold for a guy's pulling truck(I hate cast iron, but he had a cute daughter my age :roll
. The crack was only about 3 inches long but the prep of the joint, pre-heat, welding, post-heat, and prayer took about 7 hrs. Even then, I told him there was NO GUARANTEE that it would come out right, even though it did. Now, all I got was a free dinner out of the deal and no date with the daughter
Hardly worth it, considering I owed my buddy dinner for standing there with the torch continuously keeping the manifold at temp.
There was a thread on here somewhere where a guy machined the intake off flat, IIRC, and used fasteners to attach an integrated exhaust/intake manifold. Your odds for success, to me, would be much greater if you bolted an intake manifold to the planed off head.
I'm not trying to discourage your plan of six individual carbs, it's something I've been reeling over in my mind since I modified my log intake for a direct mount 2bbl. I just don't want you to bank on the welds working out and then be in a bad situation because you're chasing cracks with more weld and making more cracks in turn.(it's a bad situation, I've been there)
Good luck with your build, I'm anxious to see as it's something I'm really considering.
Stephen
EDIT: The thread I was talking about with the completely flat port side of the head is by JGTurbo in the turbo section.... The name of the thread is Mod-Log Turbo'd 250 Build.
