Am fitting an aftermarket ignition system and cannot get the std tacho to work, even after hooking the input wire to the negative of the coil.
In std form, the XD tacho ran off the negative of the coil ( bosch electronic magnetic reluctor), so I am a little perplexed as to why the tacho still won't work.
I have had the tacho tested and it's o.k.
any suggestions? What are the signal requirements other than !2 volts? the genuine ford manual doesn't say anything.
