Bayrunner
O.K. Gents. Here is what I have.
A 250ci fully worked over that needs to be ballaced. I do have the flexplate as well as thw 2v harmonic ballacer which are both 0 ballanced. Now, I am adding a custom one off 31-1 trigger wheel to the balancer in order to run the edis and ms. My question to you folks is this. Can I get the rotating assembly ballanced and then the harmonic balancer ballanced once I fabricated it back to zero balance or do I need to ballance the entire rotating assembly all at once? I could do this but it will require more time as I have to assemble and then re-assemble to ballance and then assemble again. Any info would be appreciated.
Cheers
Cheers
