66200i6
I was looking for one thing and found another. I had been trying to decide on the early head with 1.5 ID intake and small valves or to go with the later large valve head on the 200. If the pro's are reduceing the valve size it makes you think. Check the quote below.
Has anyone worked with an outfit that ran your new head on a flow bench? What are your thoughts?
Thanks in advance, Ric.
Hot Rod
Tips & Tricks
Why Small Ports and Valves Work Better
Forget colossal port sizes. They don’t work. When working on cylinder heads, the idea is to gain flow by making the port more efficient. A large port is usually lazy. The flow has no energy. Need proof? At one time it was likely possible to drop tennis balls down the ports of a Pro Stock engine. Today, they’re rather small (so small that the exhaust valves typically measure 1.80-inches in diameter, and will no doubt shrink even more over time). Certainly the port size required for a 500 cubic inch Pro Stock engine is larger than that for something like a 468-inch street machine combination, but the idea is to pack as much velocity into the port as possible. For example, Reher-Morrison has come up with a "smallish" oval port configuration for Big Chief-style 14-degree heads used in any number of Super Category bracket-race big blocks. This port is considerably smaller than what is currently in vogue. But there’s a catch: While the port looks small, it actually flows well in excess of 500 cfm. Those are numbers once reserved for the most elite Pro Stock cars, yet today, the configuration is available to anyone.
