If any of you had been following my previous postings here's where I am at. The motor is comming out, again!
I finally accepted the fact that one of a few things happened:
1. I cracked a piston ring.
2. I had a pistong ring that just won't seat.
3. I glazed one or more cylinder wall(s).
4. I did any combination of the above.
Bottom line is that in order to fix it right I'll have to have the motor out of the car. This time, I am just going to drop the money and get it done all at the same time and have the machine shop put the motor back in and time and tune everything for me. I swear if this wasn't my daily driver, I would just play around with the timing and tuning until I found the sweet-spot, but since I don't know near enough about timing and tuning gas engines, I'll leave it to someone that does it daily.
For those of you in Arizona, I still highly recommend King Balancing. The only reason I am not going to them with it this time is that they cannot remove and replace the engine in their shop. I have found a few machine shops that can R&R the motor. For those of you in the market for a motor. I found a shop in Glendale Arizona that sells short and long block 200s. Now I know Ford didn't make a ton of the 200 I6's, but I was really surprised that a 302 long block was cheaper than the 200 I6.
Short / Long
2300cc 71-81 $499 $749
200 6 cyl 65-74 $449 $699
289 V8 63-67 $399 $699
300 I6 65-86 $499 $699
302 V8 68-85 $399 $649
351 W V8 69-84 $449 $749
351 M V8 75-up $549 $749
360 V8 68-76 $499 $799
390 V8 65-76 $499 $799
400 M V8 75-up $549 $749
460 V8 2Y 68-78 $649 $999
460 V8 3Y 79-86 $649 $999
For any of you interested in this shop:
http://www.fivestarengines.com/
Ted
Short / Long
Ted
