The DUI should be fine if vital servicing is done. The design is noted for its hot 50KV spark plus easy service and spark re curving. It does everything the first years Duraspark could do. Its just the HEI mounting and its DUI brand issues that stop it being a first choice.
We are learning more about DUI. I'd personally use whatever FoMoCo part you can find, but remember, the DUI problems are known about, and you can fix them cheaply. If you don't have a Duraspark or Duraspark II, and you can get the DUI for less and not have the substandard replacement parts the Duraspark after market can dribble out, its probably "six of one, half a dozen of the other". The Size of it, the mounting of the HEI, well, its all personal choice. If you don't have Duraspark on your car, it isn't a silly step to get a DUI, but it'll need a little work.
Duraspark II offers a
lot of advantages. One of the best is the I6 Duraspark II blue strain relief versions of these distributors to a common Chrysler 5‐pin module. So does the first Duraspark (retro-respectively known as the Duraspark I systems from 1974 to 1975 and in CA till a few years later on some Windsor and 335 based engines).
The earlier system, if you can find them, are better even than the later Duraspark II systems.
Ford re-engineered the Duraspark II to allow for safety concerns, and for it to work in cahoots with the emerging Duraspark III system.
The earlier i6 Ford and AMC systems have a smaller cap, and the
Black or
Green strain relief unit, some California market ones are
Red. The AMC variant used in Jeeps and AMC sedans has its own system, then they hopped over to the Duraspark II.
The Duraspark I system (so called) is a rework of the stock Presolite based Autolite/ Motocraft ignition. Ford bought out Presolites Autolite in 1961.
The early Duraspark uses a system that potentially can take a person out with an electric shock. Its primary differences are listed by
George P, the Pantera International President Forum Administrator. The info is biased to Cleveland 351 engined cars, but it covers the differences.
cf http://pantera.infopop.cc/eve/forums/a/ ... 7731000846
An OEM style Duraspark 1 module, having dynamic dwell, is one of the most sophisticated ignition modules you can buy. Use it as designed with the proper coil and no ballast resistance and you'll have have an ignition system that properly charges the coil over a wide range of rpm, and an ignition that can ignite mixtures others cannot.
So the MSD 8477 distributor and Duraspark 1 module (with the Duraspark 1 coil) would comprise one of the best distributor based ignitions you could assemble for your Pantera. I can provide Motorcraft & Standard Motor Products (SMP) part numbers for the module and coil if you're interested.
