bigcatchdaniel555":1n6ck8mh said:i bought a pertronix 2 system and used it for about a month before throwing it away it worked alright for the first few weeks and smoothed out the idle i didnt have the flame coil i used my stock 12v which was fine but after a while of driving the car it would stop firing on 2 cylinders no matterhow i adjusted it replaced coils or took ohm readings it always went back to the ignitor i now just rely on simple points and they have great for a while now.
I have found the PX II is sensitive to the quality of its ground connection. It senses current flow and compares that to frequency to adjust dwell time. A noisy (crappy) ground drives the processor inside nuts, and it 'hunts' for an appropraite dwell, which can cause randome misfire. (I've verified all this with both an old Hitachi 20MHz analog scope and a Snap-On MODIS scope function). Extended operation with a poor ground can also lead to premature failure of the output transistor. (happened to me). PX stepped up to the plate, and replaced my unit for free (lasted about 15hrs with the poor ground), and I have not had a bit of trouble with the second unit (about 100hrs). What clued me in was PX's failure analysis report that arrived with the replacement unit. It suggested I inspect the distributor grounds. Diagnostics revealed just over 1v drop across the ground strap in the dizzy (from the breaker plate to the baseplate). That's what lead me to scope it, and the erratic pattern I found verified the fault. replacing the strap (just made a new one with a piece of bare 14ga stranded and two crimp-on eyelets, soldered after crimping) flattened out the voltage signal across the ground circuit, and reduced ground-side voltage drop to 0.009v.
