rustywagon
I was parking my car, put reverse in gear, something snapped and engine died. I can't start it, the car is "free" in all gears, resp. you can push it free in D. The distributor doesn't spin when I turn starter on. Not sure what happened. I am dissembling front to see if timing chain snapped, while removing radiator the transmission liquid started to drip from tranny cooling line.... Any advice/tips appreciated! Thank you, Michal
congrats that's good news that everything checks out. Which seals are you talking about the oil pan gasket end seals, the front cover seal, rear main seal? Yes the oil pan should be removed to clean out any trash or debris, check the oil pump pick up screen is clean too. The one trick to remove pan while engine block is still bolted in is to unbolt and remove the round tube belly bar connected across from the lower control arm mounting under the engine. The other way to do it is unbolt the engine mounts and rasie the engine up enough so you can get the oil pan out. Good luck
