I've already started porting an M (flat log) head and it will go to the michinist soon. Before it goes, I need to finalize my plan so here are some questions for the experienced among you.
I'll be raising the compression to above 9:1 by milling (best target cr??). But on an otherwise stock 200, is it worth any gain to:
1. Mill the log to accept direct mounting of my weber 38? I'm concerned that such a big hole will have too low port velocity to run well at low revs.
2. install bigger exhaust valves but leave stock intake valves? I've got a header and big exhaust. I'll have the pocket ported intake and the bigger carb, but with a stock cam big intake valves seem like they'll cost me too much on the low end which is were I'll generally be.
3. Hardened seats: Most beneficial on exhaust, intake, or equally important to both?
