73GreenMachine
I have a 1973 TC Cortina with a 250 pre crossflow and I think the starter may need replacing. The one on there is original and I think the teeth arent properly disengaging because there is an unusual (whining) noise from behind the motor. We checked out the spigot bearing (custom for a Toyota 5 speed) and the gearbox/clutch/throwout bearing etc but it does not appear to be coming from there. I have been told that later model starters ie EF-AU Falcon will fit and was hoping to confirm this before I go and get one. The Bosch catalog doesn't list the TC Cortina, but it lists the same starter from XP to AU Falcon. Would I be right in assuming that the later model starter will fit?
