I know, I know, I know...why am I bringing this up, again, for the uptenth time. Well I'm still alittle bit unsure about the whole issue of engine timing. Especially when one person might use different terminology than another person.
The easiest way to find TDC (without measuring devices) is to spin the crank until the #1 piston is fully extended in the cylinder wall on the intake compression stroke, right?
The distributor rotor should be pointing dead center on the #1 spark plug wire (nevermind the numbering on the cap as long as it's all plugged correctly) right?
Once I've done this, I should crank the engine until it lines up with 6* BTDC as indicated on the blocks timing tag. Noting that this will slightly rotate the rotor sightly ahead of the #1 plug location on the distributor.
Now assuming I stated all of this correctly I should then be about to advance the timing with a turn of the distributor as I tune the engine, correct (vacuum plugged, of course)?
Having said all of this, what if 6* BTDC is really not 6* BTDC as indicated on the crank markings?
-Chris
-Chris
