Still working on getting the engine running
TheDude
As some of you know, I fired the engine up successfully several times after the 2bbl carburetor upgrade but then it stopped working. I bought a new solenoid (I was pretty sure that would solve it) but that did not help. I am now thinking that it is the ignition switch that is giving me trouble. I am going to buy a new ignition switch online and while browsing around I thought about getting a new coil. What kind of coil should I get for my 1968 200ci I6? I assume I should get a Flamethrower coil because I hear great things about them. Can I use a FT coil with my stock ignition?
Thanks,
Justin :wink:
Justin, you need a test light or a voltage meter to find if you have power to the solenoid,starter,coil + side. if you have a pertronix setup use the flamethrower coil. if you have a duraspark with the msd use a msd blaster coil. just get in there with a test light & see if you have power at the right spots. good luck. :idea: william
not only POWER in the right spots but GROUND (earth for you aussies). I have chased a non-startion problem on a pickup I bought for a week trying different things, cables, solenoid, starters only to find that there was no ground from the battery to the body, none.. that sucked but was easily fixed..
-ron
I used a multimeter and tested the voltage from the battery to the solenoid and they both registered 12.5 volts. I also measured from the solenoid to the starter and that also registered 12.5 volts. I did not measure the coil yet. I checked all the grounds as well. I will re-check everything tomorrow. I would like to do a Petronix setup in the future. Can I still use the Flame Thrower coil with my stock setup?
Thanks for the help. :wink:
I'm pretty sure you can run the FT coil with the stock ignition, but you MAY have to use a ballast resistor (in addition to the stock resistor wire)... I say MAY because hotter coils have a tendency to burn the points up quicker.. MSD Blaster coils include the resistor in the coil kit for this purpose...
If you can swing the $$, I'd recommend getting an Ignitor (I'm assuming you already have a non load-a-matic dizzy).. especially since you've just done the 2 bbl upgrade.
