For those who have actually done it, what is the maximum horsepower output a turbocharged 250 with stock internals can sustain and survive in a daily driver (not beat on daily though)? My big MHI 16g seems to run out of steam at 4500 RPM, which is fine for me and push 10 PSI at the manifold, but I am dropping 4 PSI across the intercooler, and 14 PSI is the maximum output I get from my little turbo on a "big" six. My timing is limited to 10 degrees mechanical advance + 17 static, running no ethanol content 93. I ask because I breifly bypassed my FMIC, and registerd 14 at the manifold and the car pulled amazing for an old six. What are your thoughts on running this turbo without an intercooler on E85 at 14 psi? IAn option would be to upgrade to a larger turbo that can push 14 through the FMIC, but I would have to rebuild my J-pipe and downpipe to clear the larger compressor housing for a 20g.
My setup if it matters: Stock '77 250, felpro headgasket, CI 302 valve springs, CI chromoly pushrods, OEM adjustable rockers, duraspark II w/ 925 recurve kit welded slot to 10 degrees max, accel 300 ignition, motorcraft 42's gapped at .030, stock 4 degree retarded cam and timing set, direct mount autolite 2100 1.08 rejetted and PVCR's drilled to .063, AEM wideband O2, modified Carter superstrip for boost reference, all AN lines fuel/oil lines, MHI big 16g, ported TD05 exhaust housing & oem exhaust manifold, internal wastegate shimmed inoperative for testing, 2-1/2" J-pipe, 3" down pipe wrapped and exhaust, 2-1/2" charge pipes, bosche BOV, 12x12x3 FMIC, K&N filter.
C4, B&M sh%t kit, 8" 3.40 open
A big THANKS to all the guys who created the great write-ups and answered numerous questions!!!
