I have in hand a full set (12) of the Barker Hi-lift rocker arms that I have yet to install. The reason being that my stock rockers are so worn on the valve ends that I can't get a good setting using a feeler gauge on some of them, and I get some clatter. I got them off EBay before the price went from 50 to 100 per set (6). Some years ago, I changed from the self-locking adjusters to adjuster screws with lock nuts from a V8, and the adjustment seems to hold quite a bit longer than it did previous to the change. I don't really feel that a main bearing girdle would be necessary, as you could only push so much through the crank anyway. The block does seem to be rigid enough. The engine was marketed as a MPG engine and not a HP engine, and therefore I feel the cam is not that radical anyway. That being said, I do not know what the numbers for the cam are. I do get 23 MPG in my 62 F100, but I have installed a T5 behind the 223 and that is with a 3.70 rear.
Fred
